TractorLinks.com
Show Parts for Model:
Re: Need a little clarification on setting valves
El Toro
06-25-2013 17:24:19
Bring No1 piston to TDC on the compression stroke, then set valves 1-2-3-5 counting from the fan end of the engine. Rotate the engine one full revolution and set valves 4-6-7-8. Set the clearance at .017" cold. Hal
paul shuler
06-25-2013 17:33:53
 Re: Need a little clarification on setting valves in reply to El Toro, 06-25-2013 17:24:19
Thank you for the fast reply. Is one rotation of the engine when the fly wheel comes back around to line up with the timing mark. Is that one full rotation. Hope this is not to dumb of a question.
El Toro
06-25-2013 17:53:46
 Re: Need a little clarification on setting valves in reply to paul shuler, 06-25-2013 17:33:53
One full revolution after setting the first 4 valves. No4 piston should be at TDC on the compression stroke. Use a long plastic straw once you feel compression on No1 piston and watch the straw rise as a helper slowly cranks over the engine. Hal
CNKS
06-25-2013 17:52:52
To clarify so that you know what you are doing 1,2,3,5 are done with TDC on #1 -- 4,6,7,8 are done with TDC on #4. I make sure I am feeling air with my finger when cranking and then line up the marks. That is a foolproof way to do it.
