Sickle bar mower identification
Woodby
I got this with a 1950 Super A. It's now on my 52 Super A but I don't have a clue to what model it is. Any ideas?
If side mounted,pitman drive,its an A-22. If rear mounted,pitman drive,its an A 21 or A 24. If pitman drive,side mounted industrial type,its an A-23. If you can get the picture to load,that will confirm. However some models of the pitmanless mowers were also adapted for use on the Super A.
I started searching images of the a21 and a24 and had mixed results. I also found the a16 model looks pretty similar. I really wish my pic would upload! Thanks
the only difference between the A-21 and A24 is on the rear the A-21 has one spring where the A-24 has two. THe A-16 is manual or exhaust lift for the plain A.
