Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 460 diesel fuel system problem
Dieseltech
06-18-2013 04:29:59
Pump most likely needs repair as retainer ring is failing and plugging the one way check valve at tank bottom return line. Test by leaving the 2 timing cover screws loose so fuel can leak from housing, if it runs then the pump needs repair and fitting cleaned or replaced. High housing pressure will shut down this type pump.
Bryce Andreasen
06-18-2013 10:28:16
 Re: 460 diesel fuel system problem in reply to Dieseltech, 06-18-2013 04:29:59
I am decent at mechanics but no pump shop lol, is this a repair that can be done on the farm or a fuel shop?
Dieseltech
06-18-2013 15:03:47
 Re: 460 diesel fuel system problem in reply to Bryce Andreasen, 06-18-2013 10:28:16
If you like call 5748934172, can explain more then.
RustyFamall
06-18-2013 11:21:41
A decent mechanic is capable of removing and re-installing a diesel injection pump, but it takes special tools, equipment, and knowledge to successfully repair and/or rebuild any injection pump.
No, it is NOT a do-it-yourself job. Take the pump to a diesel shop.
