Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 806 D Alternator
Jon Hagen
06-17-2013 22:43:01
If your "1 wire" alternator is a Delco SI type with the long rectangular regulator plug at the rear outer edge of the alternator case. (terminals set up like this[- -]. Then there is a good chance it will work with the charge light.
Go in the regulator compartment down in front of your feet, remove the old regulator and make a jumper wire with male blade connectors to jumper the regulator plug terminals at opposite(outermost) ends of the plug. At the alternator, connect the "F" wire from the old square plug in the tractor harness, to the #1 regulator terminal in the new alternator, using an alternator harness repair plug from an auto parts store for any 74-84 GM product. Connect the small white(#1) plug wire to the harness "f" wire at the alternator. Also Connect the larger (#2) red in the new alternator plug to the "BAT" stud on the alternator rear using a ring terminal.
Thats it, the gen light should come on when you turn on the ignition and go off when the engine starts. The alternator is also now wired so any common 3 wire Delco SI alternator will work as intended if the "1 wire " alt ever fails and needs to be replaced.
I did this exact conversion to my 856 a couple years ago.
Jon Hagen
06-17-2013 22:54:09
 Re: 806 D Alternator in reply to Jon Hagen, 06-17-2013 22:43:01
I should have added, connect the original heavy Bat wire in the original tractor harness, plus the red #2 wire from the new regulator plug, to the "BAT" stud at the rear of the new alternator.
My advice is assuming that you do have a Delco SI series "1 wire" alternator that uses the regulator plug shaped like this [- -].
Good luck, that SI series Delco alternator with the built in solid state regulator is much more reliable and has much better voltage control than the original Delco 10 DN with the external mechanical regulator.
Jon Hagen
06-22-2013 17:21:34
 Re: 806 D Alternator in reply to Jon Hagen, 06-17-2013 22:54:09
If your wiring harness is in good condition, there is no reason to cut it up to install a 10SI alternator. When doing a rebuild of my 856, which included $500 of new wiring harness. I was not about to cut anything up to convert from the stock external regulator 10DN alternator to a 10 SI type. I was able to simply adapt the wiring by removing the original external regulator( in the compartment down by your feet) and simply making a jumper wire to connect the outermost right and left regulator plug terminals.
To adapt the wiring at the new 10SI alternator, all that was necessary was to install an auto parts store harness repair plug designed for most any 74-84 GM product with 10 SI alternator. You attach a blade terminal to The white (#1)wire from the 10 SI alternator plug, and plug it into the F terminal of the tractors original harness alternator plug
Tape up this connection to protect it from weather or shorting. Connect the heavy red wire from the new alternators regulator plug using a ring terminal to attach it to the BAT stud on the alternator rear. This is all that needs to be done to adapt the original external regulators 10DN wiring to an internal regulator Delco 10 SI alternator. This will wire the tractor so the stock charge light will work with a ("1 wire") 10SI type alternator, or any standard 3 wire 10 SI alternator. The original IH charge light works with no other changes.
The attached picture is of the several year old conversion done to my 856. The lump where the white wire enters the harness is the original harness alternator plug still atached. No need to cut up the original harness. It adapts easily to the 10SI type alternator.
