TractorLinks.com
Show Parts for Model:
Re: Odd problem with a Farmall 340 part 2
Duner Wi
06-17-2013 19:07:53
Is it possible for the cam not is not retained properly and is bouncing for and aft? Might not be possible on that engine.
old
06-17-2013 20:55:06
 Re: Odd problem with a Farmall 340 part 2 in reply to Duner Wi, 06-17-2013 19:07:53
Well on the IH distributor you have a tang then a set of gears off that tang. The gear on the distributor is what went bad and lost a few teeth so it would spin some times then not and in turn make for odd sort of start no start problems
MN Mike
06-18-2013 07:05:26
 Re: Odd problem with a Farmall 340 part 2 in reply to old, 06-17-2013 20:55:06
I googled the part numbers and got an off-brand distributor for mine complete with shaft and gear for what Case IH wants for just the shaft/gear.
old
06-18-2013 08:12:26
 Re: Odd problem with a Farmall 340 part 2 in reply to MN Mike, 06-18-2013 07:05:26
This site lists the distributor shaft for $26 or some such low price. My worry is if the one gear is bad is the drive gear also bad
