Super MTA IPTO leak advice
MattF-8
Hello, I have a MTA that is dripping oil out the side shaft of the IPTO. When parked it will leave about a 1 ½ circle of oil. Have any of you guys had any luck using stop leak products? I know I need to just take it a part and fix it right, but just don’t have time now. Thanks for the advice, Matt
I wouldn't use any stop leak products because the two $700 bands require a certain amount of friction to function properly and I wouldn't want to take my chances on a $1400 screw up. If it is only a 1.5" circle I would add oil once a week and run for a couple weeks until you have time to fix it right.
