Zenith Carb on 1945 Farmall A
Hello. I have a Zenith carb on my 1945 Farmall A. I would like to know what model that they used, I dont see any numbers but did see ZENITH on it. I would like to rebuild the carb and would like to know what kit you all would recommend? Do you all know were I can get a manual for this carb? Prefeabaly online if I can. THANKS ALL Anything else you can tell me about this carb will be GREATLY APPRECIATED. THANKS
Stevie,
Go to the parts section of this web-site(YT). They list the carb numbers and kits for the different models. Last year I bought a Zenith carb from this site, was surprised how fast they shipped it to me, and its still working fine. If you have a problem with which kit to buy, call YT, they will help.
Best Regards,
Charlie
First are you sure the carb is original. If it is there is a round plate on the top brass circle with rivet in the center that plate will have a #. If there isnt one you have a replacement of some kind. Is there a choke lever on the outside little spring type thing. Which kind of a kit do you want just gasket and needle and seat. Why do you think it needs a rebuild. Sometimes you need small drill bits to clean the idle circut compressed air dont always get the passages entirely clean.
