TractorLinks.com
Show Parts for Model:
Re: Hydraulic Pump
Owen Aaland
06-17-2013 15:31:36
If your pump is worn so that it is low on performance the repair kit will not normally give you very good service. If the pump has much wear on it the bushings will be worn and very little wear is necessary before the gears start to rub on the housing and will cut out the aluminum. The kit only contains the side wear plates and soft parts.
