Jeff77Indy
New User
I just purchased a 1300 and have some questions. This mower is missing the rear belt shield/guard. Is the dealer the best place to come up with this? Also this mower has the PTO shaft and hitch on the rear for a conditioner/crimper is the shield metioned above different or just cut out for the shaft?
I also saw a 1300 on E-bay with a hydraulic lift for the cutter bar that attached to the rear hitch can the cylinder bracket be purchased or will it need to be fabricated?
Last question as I don"t have a operators manual yet at what height off the ground should my 3pt be set for normal operation?
Thanks
Thanks
