Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Little Genius plow share help please
Jim Becker
06-17-2013 09:31:12
Based on your moldboard number, it appears you have either a HSKA (high-speed general purpose) or AHHSKA (if you have an adjustable heel). It is 16 inch. Any of these shares should fit:
and probably anything else you happen to find that starts with a letter "O" and has the numbers 582, 664 or 556. These shares are various combinations of
alfalfa, cobblestone, regular, deep suck
soft center, solid, hard surface, chilled.
The only reason I could find these numbers is because you provided the moldboard number. Otherwise, any suggestions would be just a guess.
Chuck in NH
06-17-2013 10:09:35
 Re: Little Genius plow share help please in reply to Jim Becker, 06-17-2013 09:31:12
Jim, what is an (AHHSKA) adjustable heal? New one on me. And would high speed bottoms be used with steel wheels like(forgot to mention) my plow has?
Jim Becker
06-17-2013 14:14:47
 Re: Little Genius plow share help please in reply to Chuck in NH, 06-17-2013 10:09:35
The heel is the small more-or-less triangular piece at the back of the landside. An adjustable heel is mounted with the bolt in a slot so the heel can be moved back/down on the landside. It mostly shows up on later plows.
For older plow bottoms, "high speed" means speeds up to 5 mph without throwing the dirt too far. Many of the older moldboard designs turned the soil too sharply and would only do a good job at lower speeds. I think the high speed bottoms started becomeing popular before steel wheels had totally lost favor. So a high speed bottom combined with steel wheels may not be real common, but probably not all that unusual.
