problems with picture ads
Anonymous-0
For some reasons all the pictures on this site load
for me on my computer except for the photo ads, this
just started anyone else ever have this problem????
(quoted from post at 03:46:46 05/26/13) For some reasons all the pictures on this site load
I just had the same problem, I use firefox browser. I had installed an add blocker that was stopping only the photo add section. Shut off add blocker and pictures loaded
(quoted from post at 04:01:51 05/26/13)
I've got the same problem. I installed the ad-blocker for a very good reason and I am not going to shut it off. Just seems rather strange that I used to be able to see the pictures with the adblocker running, and now, after YT made some changes, I can no longer see them.
The security of my computer is more important than me being able to see some pictures, so I guess I just won't visit the picture ads anymore.
You should be able to turn off the blocker(s) just for this site and it's domains it uses. I also had to turn mine off for to get the photo ads.
Rusty, you can leave the ad blocker running. Just
tell it to approve all ads from photos.yesterdaystractors.com (the
domain the ads are on)
(quoted from post at 08:35:40 05/26/13) Rusty, you can leave the ad blocker running. Just
But I have never told it to block ANY ads from photos.yesterdaystractors.com.
If the photoads have been moved to a different domain, then I am concerned that by allowing the photoads to display, what else will I be allowing to access my computer?
Once again, the photoads used to work just fine. YT made some changes, and now the pictures do not display.
I have made NO changes or upgrades, so why do I need to change anything now?
I have been using Internet Explorer since it was invented and have never had a significant problem. It is designed to run in Windows, and I don't understand why anyone needs a different browser. One advantage is that Windows and its components are upgraded when Microsoft needs to. I switched to the photo ads and it works fine. Also, I'm lost about the need to block unwanted ads. This site hasn't had advertising for at least 10 years. Some websites have a lot of junk on them, but if that is the case I simply go somewhere else and am not concerned with blockage.
