3pt hitch on International W450
Redturbo
Buddy gave a W450, it died in the yard. He sold the acreage to a couple. Buddy told me that if I want come get it. I winched it onto my trailer & home I went. Cut off the horrible old loader that was on it. Already have good old loader tractor(IH560D). The W450 looks in good shape, it still turns over. Buddy thought it was a ign issue. If I can make it run again, was wondering if a 3pt hitch would fit on a tractor with big fenders/platform these tractors have. Thanks
If you took the fenders and platform off I spose you could find
an aftermarket setup that would mount up or even a factory
2pt maybe.
Casey in SD
Wardner is the world authority on matters such as this. If you've thought of it, he's done it, and has pictures. I bet he'll be along shortly to enlighten.
Underneath all that tin and platform, the axle housings are pretty much the same as a Farmall, so an aftermarket 3pt would bolt right on.
To make it work you would have to remove, or HEAVILY modify, the platform and/or fenders.
Haul it out to SD and I will send you back with a 560 gas with 2 point/ 3 point already on it.
caseman-d
