Farmall C bolts
I am starting to reassemble my governor and install my re-cored radiator. I took this apart 3 months ago, now I have these two small bolts that I am unsure of where they, does anyone know? They have a tapered end. These are off a farmall super C. Thanks
They appear to be the bolts that anchor the radiator to the radiator support bar. This is the bar that anchors the radiator to the motor and attaches to the water inlet just above the fan.
They hold the grill to the upper radiator support bar. There should be a third one that goes in the bottom front of the grill. The front one could have been replaced with standard hardware.
Dennis
(quoted from post at 17:05:45 05/17/13) They hold the grill to the upper radiator support bar. There should be a third one that goes in the bottom front of the grill. The front one could have been replaced with standard hardware.
Dennis
X2. Bolts for attaching the grill
