Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: B275 pto clutch shifter
jimb2
05-15-2013 16:58:37
Hi Scott, I have never had one apart. If you have not already tried this, I suggest you use a long screw driver to move the collar into the engaged position then when you insert the lever assembly the stop on the lever should go into the hole in the diff casting and the pin should go into the slot in the collar.
Good Luck.
JimB
Scott zy
05-15-2013 17:31:34
 Re: B275 pto clutch shifter in reply to jimb2, 05-15-2013 16:58:37
Thanks for the suggestion Jim. I'll give it a try.
