Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall A conversion
Owen Aaland
05-14-2013 20:01:55
If you still have the magneto and a separate coil it has been converted to battery ignition using the magneto to furnish the points and distributor for the secondary wiring. The magneto coil is disconnected inside and the external coil is attached to the terminal that would normally be for grounding the mag to shut off the engine. Sometimes the magneto condenser is used or it also is disconnected and another one is added at the coil. Use one or the other, not both. The external wiring should be the same as a normal battery ignition distributor.
