TractorLinks.com
Show Parts for Model:
Re: Farmall A conversion
Phil Tibbetts
05-14-2013 16:52:43
If it has mag ignition there is no power to the mag. Are you sure it is mag and not distributor?
WV Farmall
05-14-2013 16:58:36
 Re: Farmall A conversion in reply to Phil Tibbetts, 05-14-2013 16:52:43
Yes it is a mag. Another fellow did the conversion so I am not sure about the wiring. Does anyone have a wiring diagram for this conversion?
Janicholson
05-14-2013 17:54:35
 Re: Farmall A conversion in reply to WV Farmall, 05-14-2013 16:58:36
This is correct. The pressure switch is from napa and has 1/8" pipe threads (closed at about 5 psi, and open with no pressure. "T" it into the oil pressure connection. The mag cannot have any power to it it is grounded at the side terminal to make the tractor stop. If power was put to it it may nave at least burnt points if not toasted mag coil. The on off switch is a grounding kill switch.
CharlieU
05-14-2013 17:14:19
I have a bunch of wiring diagrams, 25 last time I counted, for alternator conversion on my website, charliesrepair dot com click on wiring diagrams in the top line. Take your pick for the tractor you have and the type of alternator that was used. good luck
WV Farmall
05-14-2013 17:52:12
 Re: Farmall A conversion in reply to CharlieU, 05-14-2013 17:14:19
Thanks Charlie, I am sure it will be a great help
