TractorLinks.com
Show Parts for Model:
Re: Deutz allis loader arms lack power
gbs
05-13-2013 19:30:02
could be a couple of things from what you describe,are your hoses long enough to switch them from the bucket side to the loader side of the valves,if so change them and see if the problem moves to the bucket if so check the valve spool for proper travel,if travel is correct the valve could have internal damage which is uncommon,if switching valves has the same results as before then one or both lift cylinders is leaking internally a common problem,most of the time it is piston sealing rings damaged or worn out,but pistons will crack,cylinders will score ect. neighbor had the valves repaired on his mf industrial tractor it done the same thing yours is doing,the shop that built the loader spool up didn't machine the end groove back to it's original size was the problem
