TractorLinks.com
Show Parts for Model:
Re: SC starter ring-gear replacement
mkirsch
05-13-2013 05:38:11
What do you mean "slams?" That's how starters work. After 60 years of starting, the ring gears generally do show some wear. Perfectly normal. Replace it and it will last another 60 years.
Tractor needs to be split, and the flywheel removed, to replace the ring gear.
The old ring gear is cut off with a cutting torch. The new ring gear is heated, either with a torch or in an oven, so it expands enough to slide over the flywheel.
Unfortunately there is no book that will show you "exactly" how to do this yourself. Back when this tractor was new, the dealer mechanics did most of the major work, and they had training.
