Geo-TH,In
Is this an H4 mag? I want to order distributor, rotor, points, condensor. Does YT have the best price?
Thanks George
Yep sure does look like a mag to me and yes an H-4. As for cost of parts hard to say because some auto parts stores may have them or be able to get them
Yup H4 mag. Parts prices are all over the place depending upon where you get them. This site has reasonable pricing and it supports this place.
With the current quality of new condensers i would use the one you have. Does it have good fire now sometimes we start replacing parts that real arent needed. You can get a new cap and rotor from any GOOD parts store be careful too many import stuff that is junk. I have several H-4 mags use them all the time most have been in my use for 20 pluss yrs with no replacing of parts. You will need to remove the mag to replace the condenser as it comes out on the back side. So remember where the rotor is pointed when you remove so putting it back the rotor will be in the same position. Weak spark can come from a oily or rusty rotor as they do need to sometimes be cleaned as i have bought some that they said didnt work and with cleaning great spark without new stuff. Be careful not to remove the very front as thats where the gears are that time the rotor. second place is where the points are.
I just bought the entire tune up kit. Don't plant to replace anything with the exception of the rotor and cap. They look very old. One wire end looks ugly too. I'll keep the old parts, so if the spark goes south, I'll have an old part that still works.
I'll need instructions how to take mag apart when it needs it. Thanks for the heads up. Does anyone have an exploded pic of the inside of mag?
Thanks,
George.
