Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M Starter Problem
Janicholson
05-06-2013 17:36:20
I just take things apart and repair. I have so many years doing it that it is second nature. The drive end should come off of the field frame with an easy tap with a wooden block or plastic hammer. There is to my knowledge no such thing as a 12volt brush. putting new brushes in it is a good idea. For 40 let the man do it. Jim
Melvin Ware
05-06-2013 18:49:41
 Re: Farmall M Starter Problem in reply to Janicholson, 05-06-2013 17:36:20
Jim,
The drive end of the starter was coming off the field frame easy enough but was taking the armature with it. I didn"t see how to seperate the two and was afraid the brushes were going to pop out - so pushed it back together and took it to the shop. Will have it back tomorrow.
What I understand from the shop owner is that the so-called "12 volt brushes" are smaller than the 6 volt brushes in order to reduce starter current and lessen the force from the drive against the ring gear. He feels this results in less wear and may prolong life of the drive gear. Seems like a reasonable argument when using a 6 volt starter on a 12 volt system.
Will let you know how it turns out. Thanks for your help & suggestions.
Mel
Janicholson
05-06-2013 20:45:13
 Re: Farmall M Starter Problem in reply to Melvin Ware, 05-06-2013 18:49:41
THe method most used to reduce impact from 12 0n 6 is to use #2 battery cables. Smaller brushes may reduce current, but with a corresponding increase in wear. I am not complaining, just commenting. The new drive pinion is equipped with a cushion at the gear that is the main improvement, along with not powering the pinion through a big spring. Jim
Copyright © 1997-2015 Yesterday's Tractor Co.
