TractorLinks.com
Show Parts for Model:
Re: Hey RustyFarmall!
CNKS
05-05-2013 19:15:38
"-- slightly better with
idle adjusting screw all the way in."
That is a sign that your carb is not clean. Also, 5th does not have much power anyway, it is direct drive and not geared down. When you say less power in 4th, is that pulling nothing or with a load? The 6+ mph for 4th means it is not really a tillage gear. Also the carbs on the SH thru the 560 give max power with the main jet screw 5 turns out, it is not adjusted like the non Super H and M.
This post was edited by CNKS at 19:17:53 05/05/13.
IAtractorKid
05-05-2013 21:24:37
 Re: Hey RustyFarmall! in reply to CNKS, 05-05-2013 19:15:38
Wont start off in 4th or 5th gear without the choke out. Once moving choke can be pushed in and it will continue just fine, until it starts to die. This is with no load, just the bare tractor. Main jet screw on the bottom, front of the carb (towards governor) is set 5 turns out currently, although I usually only set them about 3 turns for better economy as mine are not hard workers.
Have the carb off now and will clean again and hope for better results. Thanks!
rustyfarmall
05-06-2013 08:04:33
 Re: Hey RustyFarmall! in reply to IAtractorKid, 05-05-2013 21:24:37
Use a can of aerosol carb cleaner. NOT brake cleaner. Stick the nozzle into every orifice, and passage you can find on that carb and spray until it comes through somewhere else, and then stick the nozzle into where the spray came out and spray again. Pay special attention to the brass jet down in the bottom where the load screw fits. There is an area in behind there that SOMETIMES fills up with crud and is very difficult to remove.
When you think you have it clean, blow compressed air into each and every hole there is. If the carb IS clean, the compressed air WILL exit through another hole somewhere. If it doesn't, you are not yet done with cleaning.
Where abouts in Iowa are you?
IAtractorKid
05-06-2013 13:36:31
 Re: Hey RustyFarmall! in reply to rustyfarmall, 05-06-2013 08:04:33
Will do! Just talked with Matt at Motec Eng about it and he gave my a few things to try as well. I would have sworn In had it clean from the beginning but hopefully I missed something.
Central IA, right around Des Moines.
rustyfarmall
05-06-2013 14:26:49
 Re: Hey RustyFarmall! in reply to IAtractorKid, 05-06-2013 13:36:31
You are about 2 hours or less from me.
IAtractorKid
05-06-2013 16:24:24
 Re: Hey RustyFarmall! in reply to rustyfarmall, 05-06-2013 14:26:49
Where are you at? If I don't get it figured out, I may have to pay you a visit!
rustyfarmall
05-07-2013 07:02:09
 Re: Hey RustyFarmall! in reply to IAtractorKid, 05-06-2013 16:24:24
IAtractorKid said: (quoted from post at 16:24:24 05/06/13) Where are you at? If I don't get it figured out, I
Send me an email. If you go to the modern version, my email is open.
Apparently YT has that part of it all messed up, so here's my email.
rustyfarmall@hotmail.com
This post was edited by rustyfarmall at 07:07:51 05/07/13.
