TractorLinks.com
Show Parts for Model:
Re: Farmall Super M 12 volt conversion
buzzinduzzin
05-04-2013 17:26:16
what you need is a ballast resistor. I know nothing about a chrysler resistor but it may only function properly in conjunction with its other components. If there is a terminal on your starter solenoid that is 12v ONLY when the starter is engaged connect it to the coil side of the ballast for a hotter cranking spark.
T in NE
05-05-2013 10:35:15
 Re: Farmall Super M 12 volt conversion in reply to buzzinduzzin, 05-04-2013 17:26:16
Chrysler points ignitions used a ballast resistor with a 6v coil, with a by-pass built into the starting circuit for hotter spark while cranking.
I used one on my SM with the coil that was on there. Which, externally, is the same size that Chrysler used.
