Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall Super M 12 volt conversion
charlie M
05-04-2013 17:19:37
If the coil is 12 volts then you don't need a resistor. Adding one would create a weak spark. if you're coil is 6 volts then you need the resistor.
B. Cole
05-04-2013 17:26:08
 Re: Farmall Super M 12 volt conversion in reply to charlie M, 05-04-2013 17:19:37
Okay, thanks. I guess I have it right then but somehow it seems backwards in my head :-)
05-04-2013 17:31:01
 Re: Farmall Super M 12 volt conversion in reply to B. Cole, 05-04-2013 17:26:08
If the coil has a resistance of 4 to 6 ohms it can be used WithOut the resistor. If in the area of 2.5 to 3 ohms it needs a resistor. It could be mislabeled, or just wrong. If the coil draws less than 4 amps when turned on and grounded through the points, it can be run without the resistor. Jim
