TractorLinks.com
Show Parts for Model:
Re: Super A - 140 Steering Bushing Kit PROBLEMS
RTR
05-03-2013 09:43:32
Would anyone on here happen to have a set of the 2 bushings (new from CASE/IH) that they wouldn't mind measuring for me? It would be nice to have the CORRECT dimensions so I could check the replacement bushings in the last kit that I have. That way, I could know what to expect to do IF I decide to order another kit, and I could also help the older guy out that is in need of assistance.
Janicholson
05-03-2013 17:24:08
 Re: Super A - 140 Steering Bushing Kit PROBLEMS in reply to RTR, 05-03-2013 09:43:32
YThe bushing should have a .001 to .0008" interference fit into the housing. If machined to that diameter on the OD, it will not "shrink" very much on the inside when pressed in. THe inside might need to be reamed to the worn shaft diameter for perfection. (the shaft might need to be ground to allow the smallest diameter to be the only diameter and fit to the bushing). Some "kits" are intentionally designed for Pro fitting of components. Best of luck, it is doable.
