TractorLinks.com
Show Parts for Model:
Re: Super A - 140 Steering Bushing Kit PROBLEMS
RTR
05-03-2013 07:13:41
Here is the kit I purchased....and this is the person I got it from.
http://www.ebay.com/itm/New-IH-Farmall-A-Super-A-100-130-140-Steering-Sector-Bushing-Bearing-Repair-Kit-/230900269927?pt=BI_Heavy_Equipment_Parts&hash=item35c2ba8367
Janicholson
05-03-2013 09:35:19
 Re: Super A - 140 Steering Bushing Kit PROBLEMS in reply to RTR, 05-03-2013 07:13:41
The issue is certainly with the supplier. If no satisfaction, contact Ebay, and if that is the only issue, the original bushing was for sure the right wall thickness, so machining the replacement should produce a usable part. Jim
RTR
05-03-2013 13:47:01
 Re: Super A - 140 Steering Bushing Kit PROBLEMS in reply to Janicholson, 05-03-2013 09:35:19
I just read the description on the $teiner website for the kit I have (they are the original supplier of the kit), and they specify that you need to hone or ream out the bushings to fit your tractor prior to installation. I feel like they would have made them the exact size if they were going to the trouble of making bushings. I didn't think the shaft or casting would actually "wear" having the need for a larger bushing to be "made to fit". How would one know what size they needed to have that done? Measure the shaft and casting??
Janicholson said: (quoted from post at 21:35:19 05/03/13) The issue is certainly with the supplier. If no satisfaction, contact Ebay, and if that is the only issue, the original bushing was for sure the right wall thickness, so machining the replacement should produce a usable part. Jim
This post was edited by RTR at 14:29:44 05/03/13.
RTR
05-03-2013 09:43:32
Would anyone on here happen to have a set of the 2 bushings (new from CASE/IH) that they wouldn't mind measuring for me? It would be nice to have the CORRECT dimensions so I could check the replacement bushings in the last kit that I have. That way, I could know what to expect to do IF I decide to order another kit, and I could also help the older guy out that is in need of assistance.
Janicholson
05-03-2013 17:24:08
 Re: Super A - 140 Steering Bushing Kit PROBLEMS in reply to RTR, 05-03-2013 09:43:32
YThe bushing should have a .001 to .0008" interference fit into the housing. If machined to that diameter on the OD, it will not "shrink" very much on the inside when pressed in. THe inside might need to be reamed to the worn shaft diameter for perfection. (the shaft might need to be ground to allow the smallest diameter to be the only diameter and fit to the bushing). Some "kits" are intentionally designed for Pro fitting of components. Best of luck, it is doable.
