TractorLinks.com
Show Parts for Model:
Re: Hotter spark plug
old
05-02-2013 12:11:19
Why do you want hotter??? Does it use a lot of oil or what?? You can only go so hot before doing so causes many other problems like holes burned in the pistons and or burnt valves.
Bob Reineke
05-02-2013 13:36:58
 Re: Hotter spark plug in reply to old, 05-02-2013 12:11:19
Ive tryed about everthing I can, and gas keeps fouling the plug once it runs a short time
GordoSD
05-02-2013 16:45:56
 Re: Hotter spark plug in reply to Bob Reineke, 05-02-2013 13:36:58
Gas can't foul a plug. Oil or soot will foul one. What is on the plug? Black greasy residue or black carbon soot? And is it on ther electrode or the insulator? You need to determine wheter you have a fuel probllem or an oil problem. Then go after that.
Bob Reineke
05-02-2013 17:12:08
 Re: Hotter spark plug in reply to GordoSD, 05-02-2013 16:45:56
Its clear and wet and smells like gas. No soot or oil residue
GordoSD
05-03-2013 07:11:22
 Re: Hotter spark plug in reply to Bob Reineke, 05-02-2013 17:12:08
If it is clear and wet and smells like gas it is probably gas. But that plug is not fouled. It is wet because that cylinder is not firing. Start the tractor, listen to it run. Now disconnect that "fouling plug" wire. Bet there isn't any differenc. Now check for big blue spark on that plug. Got one?
Bob Reineke
05-03-2013 08:20:58
 Re: Hotter spark plug in reply to GordoSD, 05-03-2013 07:11:22
It's NOT firing and has what looks like a strong spark but it's not blue. Iv'e checked the points the distributer cap, wire all looks good.
Indiana Ken
05-03-2013 18:20:55
 Re: Hotter spark plug in reply to Bob Reineke, 05-03-2013 08:20:58
You stated you have checked the wires, distributor cap etc. I have had carbon tracks on coil towers and inside distributor caps, they are hard to see and inside the cap they can prevent firing on a single cylinder. I have had bad wires that looked good and actually checked good with a ohm meter. Checking the spark by pulling the wire and watching the spark jump to ground does not always mean it will fire inside the cylinder under compression.
If your other plugs look good, if it were me, I would replace the distributor cap, rotor and wires with new ones. If that does not fix the problem then I would look else where. Good luck.
Bob Reineke
05-03-2013 21:05:03
 Re: Hotter spark plug in reply to Indiana Ken, 05-03-2013 18:20:55
Thanks for the info
GordoSD
05-03-2013 18:04:33
Replace the wire, replace the plug. Start new thread, "no fire one cylinder"
John M
05-03-2013 12:39:09
Bob, pull the plug wire off just enough so that the metal end on the wire and the metal either on the cap or the plug end dont touch, say like 1/8 inch. See if it still does it. Im betting on a bad cap. Those cracks can be hard to see.
Bob Reineke
05-03-2013 21:06:43
 Re: Hotter spark plug in reply to John M, 05-03-2013 12:39:09
OK I'll try that, thanks
rustyfarmall
05-02-2013 14:12:13
If the carburetor is set so rich that one plug is getting fouled, ALL of the plugs would be fouling.
I'm wondering if maybe the tractor does not get worked hard enough? Possibly the cylinders are all sooted up and it is a piece of that soot that comes loose, and THAT is what is fouling the plugs?
I will suggest starting it up, and then take it out and make it WORK. HARD. Put it on the road in 5th gear and pull the throttle back. Take it up and down a few hills. Don't stop until after the heat gauge has moved into the "run" zone.
Bob Reineke
05-02-2013 15:06:44
 Re: Hotter spark plug in reply to rustyfarmall, 05-02-2013 14:12:13
OK thanks I'll try that. It doesn't get worked hard at all.
old
05-02-2013 15:27:33
 Re: Hotter spark plug in reply to Bob Reineke, 05-02-2013 15:06:44
Yep hard work maybe the ticket. You also might try a quart of ATF to say 3-5 gal of gas to help clean out carbon in the cylinders. Also when was the last time you cleaned the air cleaner oil tub and refilled it with new oil. I have seen so many of them that did not get serviced that they had water and so much dirt in them that the carb had to run rich
Bob Reineke
05-02-2013 15:40:31
 Re: Hotter spark plug in reply to old, 05-02-2013 15:27:33
Thanks for the tip. The oil in the filter is clean just changed it recently.
