Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Hotter spark plug
John T
05-02-2013 11:57:05
Best I recall the Autolite 3116 is in the vicinity of the heat range around a 386 or hotter 388 Autolite. However its a non resistor plug I believe which Id especially recommend if you had a Magneto Ignition.
Other things which can help if fouling is a problem for which youre seeking a hotter plug is to use hotter thermostats (if a T stat tractor) or radiator air deflectors or shutters etc TO RAISE THE OPERATING TEMPERATURE,,,Dont run the carb richer then necessary,,,,,,,,Use wire core plug wires, keep the ignition well tuned.
John T
Bob Reineke
05-02-2013 13:34:18
 Re: Hotter spark plug in reply to John T, 05-02-2013 11:57:05
Ok thanks for the info
