Hiesler Overdrive ????
I"ve just installed a Hiesler overdrive on one of my F-14"s. Can anyone provide me with a picture of how the shifter rod/arm mounts? Do I have to drill a hole in the rear gas tank support to get the rod through? I don"t know if the rod is bent at the right angle or not so a picture would be helpful. Thanks in advance.
If you happen to have access to the May-June 2005 issue of Red Power, there is an illustration from the Heisler catalog (on page 6) that might answer your question.
