TractorLinks.com
Show Parts for Model:
Re: Farmall A, Round 3
Janicholson
05-01-2013 20:28:29
Mark four locations with white paint or whiteout marker equally spaced at 90 degrees apart on your front pulley. The first of which being easy to see when the #1 cylinder is at TDC. these marks are not true timing marks, they are to be used for checking dwell variation. As the points open and close, the accuracy of the cam lobe and the opening of the points (distributor or mag) can make radical timing changes. Use a timing light hooked to the coil or mag coil wire not #1 plug. this will fire at every cylinder, and the marks should stay very close together when flashed. if they are even 1/4" apart from each other the ignition cam and or bearings are toast. Jim
