TractorLinks.com
Show Parts for Model:
Re: gas fouling # 4 plug
gene bender
05-01-2013 15:50:39
The problem is not the gas you probably have a bad wire or maybe the valves in that cycl arent set correct. You can also take that plug and replace from another cycl that would also tell you if the plug was bad but gas is not the problem. How does that plug look when it quits firing good like other post says maybe a bad cap. But if you change plugs from another cycl that will prove the problem is the wire or bad set on the valves. BTDT with other used tractor ive boughttill i found the problem. Just do one thing at a time so you can find the problem.
Bob Reineke
05-01-2013 16:35:28
 Re: gas fouling # 4 plug in reply to gene bender, 05-01-2013 15:50:39
thanks, the plug has a strong spark intake valve sounds like it
