806 with injector line leak
jbraman
New User
My 806 diesel with a 360 ih engine has a leak on the #1 cylinder right where it connects to the injector. The compression fitting seems to be loose. Can you replace just the fitting or do I need a whole new line?
I have replaced few ferreles but they leave a deep groove in line usually so you have to cut a little off line. 250610R1 sleeve.
You only need to cut about a 1/8th inch to move the ferrele to a new spot. Totally insifinicant.
