Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1948 Super AV Tire / Wheel Wooble
04-30-2013 17:44:39
The spindle bearings (top and bottom of the vertical tube at the end of each axle.) are bushings. The bottom of the spindle is located by a thrust bearing that keeps the wheel hub down, and the spindle tube up. If the lubrication of the spindle has been ignored, the spindle will wear the bushings. this wear allows wobble. Check it by jacking the axle till the wheel and tire is off the ground. Block the axle with good cribbing to make it safe. then violently shake the wheel/tire assembly while someone waches the spindle top and bottom to see if there is looseness. Side to side more than 1/16" is about all that is acceptable. Jim
