300U hyd Index control valve
peteellis1
New User
There is an index roll pin on the back on the hyd control valve. Two possible choices right.or left.
What does it do?? Does it change for stacked valves after the first valve?
Thanks for any info
It says D & S which means double action or single action. On double you can use pressue both ways you move the lever and on single action you have pressure only one direction. In other words for using a sinlge or double action hydraulic cylinder.
