TractorLinks.com
Show Parts for Model:
Re: hydraulic fluid
IH fan
04-20-2013 14:46:37
Some fluids do not take much water to turn milky. You will almost never get all the water out unless you completely dis-assemble your hydraulic system. Best you can hope for is to drain the easy parts, reservoir, accessable lines, cylinder, etc. Almost impossible to drain valves and hidden lines. Also in cast parts, even small pockets will hold water. Water may also be causing the squirting you see. Drain what you can and maybe change it again after using it for 2 or 3 months.
