New Carb for B Recommendations
jkmdg84
I took off a carb on a '46 and will be looking to replace it. Its a Zenith 10514 from what I can make out on the plate. I was told that this isn't an original carb to a B, so just was wondering which type of Zenith I should look into getting to make it more "original"? Where would be the parts store/restoration website that people would recommend?
Do you care if it is original? If not, rebuilt it and enjoy the tractor. You have the carb number so get a kit, clean it up and put it back together. There were two brands according to my book. A Zenith and a Marvel. You may have the right carb but I don't know the carb numbers though.
My catalog lists 6 different carbs that could be on it from the factory and the 10514A so happens to be one of them in the list so your carb is in fact a factory made carb for the B as per the nnalert catalog and I bet if you checked this site and there list of carbs or checked with IH you would find it to be listed for it
As per the catalog they do in fact have them but they are not new they are in fact rebuilt.
Also note that if you had read what I was telling him his carb as per the catalog is in fact a factory carb. I was not telling him where to find one I was informing him that hos carb was correct for his tractor
Try McDonald Carb. & Ignition at Jefferson,GA. They have new oem carbs in both Zenith and Marvel. They also sell kits and individual parts for both of them.
Those are replacements and they are not like the original He seems to want an original that came on the tractor and you just cant buy a new one like original.
If you looking for a new one check out the ones they sell here on yt! You can't beat the prices!
You might have to rejet them a little if you are going to work it but I had great luck with them!
