TractorLinks.com
Show Parts for Model:
Re: coil, or distribeter
Janicholson
04-19-2013 20:58:49
If you have sideways movement in the distributor shaft more than .001", the distributor shaft bushing is worn. If it is the new distributor that you are moving sideways, it is not rebuilt correctly. If it is the old one, widening the point gap setting to .022" maybe even .025" may make it fire on all four. Jim
blunted
04-20-2013 05:14:30
 Re: coil, or distribeter in reply to Janicholson, 04-19-2013 20:58:49
what ways is there to seeif damage to coil? it will still run on 1 and 3. thanks..
Janicholson
04-20-2013 05:59:30
 Re: coil, or distribeter in reply to blunted, 04-20-2013 05:14:30
You cannot damage a coil except by physical injury, or running it on twice the voltage for 30 minutes. Neither of which apply. If it is running on two cylinders, and the ones that are dead are not getting spark, there are two issues that apply: If the distributor cam (four lobed shaft that the points rub on to open) is loose in its bearing as I described earlier, is one possible issue. A bad distributor cap with a crack or carbon track between wire towers 2 and 4 (and possibly contributed to with bad spark plug wires)is the other issue. All this assumes you have the wires on from front to back 1342, and around the cap in that rotation clockwise. Jim
blunted
04-20-2013 06:13:00
 Re: coil, or distribeter in reply to Janicholson, 04-20-2013 05:59:30
yesall the timeing checks out 9even took the gonener off for the 4th time with fly wheel # 1piston up) new wires, cap even retryed old cap put another new resister. trying to bring back a tractor that almost dont even be good for parts,. but, my freind wants it done its been one thing leads to another. thanks jim. have a rebuilt dist comeing next tuesday with also dist shaft that will slide into the back side of the new govoner assembly. i need to get it out and done so i can bring back my A and SC. thanks going on 4 mo. should have been done a long time ago.
Janicholson
04-20-2013 06:15:22
 Re: coil, or distribeter in reply to blunted, 04-20-2013 06:13:00
I think it is the shaft bearing. Jim
blunted
04-20-2013 05:15:31
this is 12 volt now that i changed it over. thanks
