TractorLinks.com
Show Parts for Model:
Re: OT Bushing a PHD auger
mkirsch
04-19-2013 12:07:23
What you want is DOM tubing. DOM is drawn over mandrel.
Normal tubing is made from a flat plate that is curved into a tube, welded, and ground smooth on the OUTSIDE. There is a weld bead on the inside which messes up any idea of fit.
DOM tubing is solid, smooth inside and out.
Metalsdepot DOT com has 2.5", .250" wall DOM tubing in lengths as short as 12". It ain't cheap, but it's the easiest way to get from A to B in your case.
Dave H (MI)
04-19-2013 12:49:11
 Re: OT Bushing a PHD auger in reply to mkirsch, 04-19-2013 12:07:23
Just happened to be checking back and saw your post. Thank you kindly for the input, that is quite helpful. I will note the link and contact them once I get the auger home and "dry fit" it to make sure of what is needed.
