Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Fast hitch rusted solid
Randy Hall
04-19-2013 11:07:14
yes they get tight. last year i had to heat that piece red hot with a big rosebud tip to get it loose and still had to beat it quite a bit with large hammer.
IH fan
04-19-2013 11:42:15
 Re: Fast hitch rusted solid in reply to Randy Hall, 04-19-2013 11:07:14
The cross-shaft under my 240U was not rusted, but eye bolt in the right arm was broken off. I was able with a center punch and penetrating oil to unscrew the stub and the eye was still there, so I had a cutoff bolt welded together to make a new one and got it back together. You could tell by the "dobbing" that the triangle plate had been welded on a new shaft. It certainly wasn't an IH weld job, but at least I had all the pieces. Since it had been replaced, maybe it was rusted solid at some time. Sure makes a difference when using a rear blade to have the swing locked.
