Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: resistor
mkirsch
04-19-2013 06:27:13
Last resistor we tried, we could only get 3V to the coil, even though there was 12.6V there without the resistor. I'm starting to think they're more of a pain than they're worth.
Used a 12V coil instead.
John T
04-19-2013 07:34:47
 Re: resistor in reply to mkirsch, 04-19-2013 06:27:13
I have observed ballast resistors in the 1.2 ohms range all the way up to over 2 so it can indeed make a difference. Ideally they should be matched to the coil so theres a 50 50 voltage divider with 6 volts dropped across BOTH the ballast and a 6 volt rated coil. Unless theres a need for the 6/12 ballast by pass system for improved cold weather starting I agree go with a 12 volt coil no dern ballast required
John T
