TractorLinks.com
Order Farmall Cub Parts Online
Re: PTO angle shaft on Cub
Farmallb
04-11-2013 09:27:56
Just called IHC in Theryer Kans. They no longer make the spacers. I can get the seal. Will used spacers work?
gene bender
04-11-2013 10:45:58
 Re: PTO angle shaft on Cub in reply to Farmallb, 04-11-2013 09:27:56
You could make one out of PVC it fits the shaft OD and is just wide enough to cover the seal and then the belt pulley will hold it in place. If you dont have a pulley make it long enough to cover the splines and use a cap screw to hold it in place. Make sure the OD of what ever you use is large enough to fit against the seals ID.
