F-20 Duckbill front end
they are not interchangeable. F30 is a bit bigger and the bolt patterns are different
if you have a pic of it we could tell you if its a 20 or a 30
No they are not the same. The F30 front end is larger but unless you are comparing an F20 and F30 front ends side by side, you may not discern the difference. The best way to tell for sure is by the part numbers cast into the individual parts.
ill take a picture of both a 30 and a 20 for you. the biggest place they are deifferent is where they bolt to the frame rail
are you looking at a parts tractor or just a bolster only?
heres the quickest way to see the difference in the two without trying to measure anything.
F-30's have a little sweptback piece on the bolster at the frame whereas F-20's dont. here are two pics. 20 is red and the 30 is orange
a big ih sale in georgia last year had a f-20 with a f-30 duckbill front end. steering rod was to tall over the f-20 radiator.
(quoted from post at 13:06:11 04/12/13) a big ih sale in georgia last year had a f-20 with a f-30 duckbill front end. steering rod was to tall over the f-20 radiator.
aumann auctions ,Dwight Purvis sale, lot # 71
