PTO angle shaft on Cub
Farmallb
Does anybody know where to get a new or rebuilt angle pto shaft for a 1950 Cub Farmall? Ive reb uilt mine twice, and I cant get it to hold oil after being run.
Just called IHC in Theryer Kans. They no longer make the spacers. I can get the seal. Will used spacers work?
You could make one out of PVC it fits the shaft OD and is just wide enough to cover the seal and then the belt pulley will hold it in place. If you dont have a pulley make it long enough to cover the splines and use a cap screw to hold it in place. Make sure the OD of what ever you use is large enough to fit against the seals ID.
Untitled URL Link
I found and bought the parts at Joes Farmall Shop. $45. He says there are 2 spacers, and each a different size. Bought the seal also.
