560 Injector leaking
Texas Allen
New User
On the back side of my 560 diesel injector pump, I am getting a steady fine spray of diesel coming out. It appears to be coming from the line, or where the line mates to the pump. Wouldn't think I have a hole in the line, but more oriented to the fitting. Being it's on the back side it's tough to diagnose. Any suggestions?
If line washers on the banjo bolt are leaking you can use 2 each of Stanadyne 11354 copper, or 16225 steel line washers. CAV/Lucas/Delphi part # 5936 332C mild steel washers can be used also.
have you at least tried to tighten the fitting.?
the shop will know all about those washers, just by asking for them.
