TractorLinks.com
Show Parts for Model:
Re: Model C float setting
pete 23
04-10-2013 17:10:56
If your float sets parallel with the carb body, the setting is not the problem. It is either too stiff on the hinge, leaky float , rubbing on side , needle is leaking or gasket under seat is not sealing. I like to test the needle and seat with vacuum, usually just sucking on it with mouth. Probably needs staking to make a good seat.
Kevin in Minnesota
04-10-2013 17:15:55
 Re: Model C float setting in reply to pete 23, 04-10-2013 17:10:56
what do you you mean by staking
pete 23
04-10-2013 18:48:52
 Re: Model C float setting in reply to Kevin in Minnesota, 04-10-2013 17:15:55
Staking is done to form a good seat. Often the new seats are not very good. Back in the day when we had steel needle and brass seat we would tap on the needle to form a good seat. With viton tipped needle this is not ordinarily done although some do it. I use a tip from an injection nozzle that has the same degree as the needle and tap it with a small hammer a few times then test it for sealing. I can't really tell you what to use because I just happen to have these available to me. Could stop at an injection shop and get an old nozzle tip from 806 up to 1586 and no doubt many other engines.
