Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: injection pump timing D282
04-10-2013 10:52:02
I went by timing of 3 degree's for 606 , so your 1 degree may be correct pete. as the earlier 282's had 3 degree's except 660 was at 5 degree's.
pete 23
04-10-2013 17:20:19
 Re: injection pump timing D282 in reply to rustred, 04-10-2013 10:52:02
Heck, I was going to say, your 3 degrees was probably right. I remembered they changed their minds and moved the timing up later on. Fact is, the very first 656 gear drive tractors had a speed advance and they soon changed to the load advance system that had been in use on the 560's. I would have to look at the book to be sure though. The hydrostatic models stuck with the speed advance as they were higher rpm engines. I like to run them as late as you can and still run smooth at high rpm's with a properly adjusted automatic advance be it speed or load style. .
