dan osborne
I have a 656 diesel that I have determined needs an injection pump rebuild. I have fuel to the pump, injector nuts are loose, but no fuel to injectors when cranking engine. On the crank pulley, there are degree markings starting with the letter A and maybe going 40 degrees to a small 1/8" pin, and then going about another 10 degrees to a letter R. I am assuming the pin is "0" degrees? I have cleaned the pulley, but all I can make out is the "0" every 10 degrees because the first digits are on the edge of the pulley and cannot be made out. I am trying to figure out where to get the timing before I remove the pump. I am thinking once I get the crank where it is suppose to be, something will line up in the window of the injection pump. Am I correct in this. Any advice would be greatly appreciated!
