Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: International 485 stuck in low gear
Cyrush
04-10-2013 07:10:54
You will probably need to lie under the l/hand side of the tractor under the gear change and use a bar to lever the external selectors back to the neutral position. Make sure the engine is off !! And the handbrake is on. If the weight of the tractor is on the transmissio it will be harder to do !!
They usually do this due to bent or worn linkages
Juliaharrison
04-18-2013 13:17:17
 Re: International 485 stuck in low gear in reply to Cyrush, 04-10-2013 07:10:54
Thank you so much. After about an hour lying under the tractor trying to figure out how to lever it back into position. I did it! Next time and there will be a next time because it is so worn out, it will be a 5 minute job! Thank you again
Cyrush
04-18-2013 15:10:16
 Re: International 485 stuck in low gear in reply to Juliaharrison, 04-18-2013 13:17:17
This is the problem on older machines, you probably need to fit some new bit to eliminate the wear!!
Do you have a service manual?? I sell PDF copies of the genuine IH manuals!! If interested send me your e mail address for details
Juliaharrison
04-19-2013 05:11:14
 Re: International 485 stuck in low gear in reply to Cyrush, 04-18-2013 15:10:16
Hi
I have the original booklet with it but it isn't very comprehensive.
my email is julia-dawn@hotmail.co.uk
Thanks
Juliaharrison
04-10-2013 09:21:59
Thank you very much, I'll have a go.
