International 485 stuck in low gear
You will probably need to lie under the l/hand side of the
tractor under the gear change and use a bar to lever the
external selectors back to the neutral position. Make sure the
engine is off !! And the handbrake is on. If the weight of the
tractor is on the transmissio it will be harder to do !!
They usually do this due to bent or worn linkages
Thank you so much. After about an hour lying under the tractor trying to figure out how to lever it back into position. I did it! Next time and there will be a next time because it is so worn out, it will be a 5 minute job! Thank you again
This is the problem on older machines, you probably need to
fit some new bit to eliminate the wear!!
Do you have a service manual?? I sell PDF copies of the
genuine IH manuals!! If interested send me your e mail
address for details
