424 international torque specs and wiring diagram
Can anyone tell me what the main and rod bearing torques specs are for a 424 international gas tractor? Also if anyone has a wiring diagram for same tractor I would appreciate one of those as well. Serial Number: 07384. Thank you.
For the 146 Engine I have these specs from IH Service Manual ISS-1039-1
Cyl head nut to stud - 85
Conn rod nut to stud - 46
crankshaft pulley nut - 140
main bearing -78
flywheel bolt -49
manifold nut to stud - 34
spark plugs - 33
oil pan - 15
The wiring diagram should be in your 424 operators manual pg's 41-42.
Randy
