Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Replacing Transmission Seal on Farmall B
Daniel H.
04-05-2013 10:11:25
Yes the shaft will slide out of the transmission as you separate the drop housing (final drive) from the transmission. It is heavy- be sure you have the hoist attached securely. Once you separate it, remove the cover over the bearing and remove the set screw from the brake drum and bump the shaft out through the drum and the final using a big hammer and a block of wood. The bearing will come out with the shaft.
